attaching prop to shaft?
Postby Jeffrey J » Sat Dec 19, 2009 4:43 pm
hey guys,
I have a 1/72nd brass 5 bladed prop "I think for an Alpha," the prop is threaded, this is what I am going to use on my Sturgeon until I can get a scale brass 7 blade prop for it. Are these just held on with a locking nut? I was thinking of drilling out the threads making a hole all the way through the hub and run the 3/16" shaft all the way through and solder on a brass cone at the tail of the prop shaft. This is what i did on another sub just to keep from looseing the prop. Thanks. Jeff J.
one things for sure, they won't be expecting us......... S/C#258
Jeffrey J
Re: attaching prop to shaft?
Postby Wheelerdealer » Sat Dec 19, 2009 5:30 pm
Yes a locking nut a drop of thread lock works fine for me. Never lost a prop.
http://www.rcmodelsubmarines.co.uk
Whaddya mean, I need a license to do that?!
Wheelerdealer
Postby Tommydeen » Wed Dec 23, 2009 4:26 pm
I drill a hole in the side of the hub and tape-n-drill 4-40 on all props threaded or not then mill a slot on the shaft in the right spot.
Tommydeen
Postby Sub culture » Thu Dec 24, 2009 6:42 am
If you really want to make sure your prop will stay put, pinning it thorough the shaft takes some beating.
Sub culture
