Photo etching methods
Postby eckloss » Sat Oct 03, 2009 9:17 pm
im going to assume that photo etching methods have changed a bit sincei last did it 6 or 7 years ago.
what methods and materials are you all using now?
eckloss
Postby raalst » Sun Oct 04, 2009 10:42 am
maybe check out a few static modelling sites, like http://www.modelshipwrights.com how those people make their own PE.
PE is much more common in 1/350 scale shipbuilding and suchlike.
I have no own experience with PE.
for etching tools you also might want to check out the electronics
DIY sites and shops. But I'm sure you knew that already.
Ronald van Aalst
Just here to Learn
raalst
Postby JWLaRue » Sun Oct 04, 2009 5:06 pm
...an even better answer:
http://www.starshipmodeler.com/tech/fh_pe.htm
JWLaRue
Postby RickNelson » Sun Oct 04, 2009 7:21 pm
Micro-Marc offers a PE kit. I purchased it some time ago but have not tried it out yet.
Rick Nelson
Qualified in Submarines 1965
SCM #2583
"D..n the pressure, Six-Zero feet!"
"Most men would rather die than think, Most of them do!" - Bertrand Russell
"Boomers hide with Pride"
RickNelson
Postby ManOwaR » Sun Oct 04, 2009 10:26 pm
That micro-mark set is a good way to learn, but if you are wanting to do a sheet of any size, that kit will limit you. Try something from Mg chemical. I don't think you end up paying anymore in the long run either. They post a pdf app guide on there too. A very easy process once you get the hang of it.
http://www.mgchemicals.com/products/prototype.html
Hope this helps,
Joel
ManOwaR
Postby RickNelson » Mon Oct 05, 2009 1:57 pm
Thanks Joel for the recommendation. When I get involved in the PE effort again I'll take your advise.
Rick Nelson
SCM #2583
RickNelson
