Bagpumper - to seal or not?
Postby subkraft » Wed Aug 12, 2009 2:10 am
Hi,
This is a pic of my nearly complete slightly modified Arkmodel Song wtc:
The reversing pump simply pumps water in and out of the bag thru the solenoid valve. The bag is suspended in a tube within a tube. The manufacturer shows this inner tube well sealed up around all joints.
I like to be able to take things apart....is it important that the tube within the tube be airtight? The only advantage I can see that it would contain the change in internal pressure as the bag inflates...
Any bits of wisdom appreciated.
Model is getting closer to finished:
“The difference between genius and stupidity is that genius has its limits.” ~ Albert Einstein.
subkraft
Postby Bigdave » Wed Aug 12, 2009 8:13 am
Depending on the pressure that is developed it could play havoc on your output seals. :cry:
I have seen that type of seal blow up like a balloon from too much pressure inside. :shock:
Maybe that is why they do it.
Give it a try on the bench and see. You can always goop it up after.
Or just ask Arkmodel. :D BD.
David Welch
Commodore SR-8
Douglas, 20K
Bigdave
