Sanding Epoxy
Sanding Epoxy
Postby Nelix6030 » Sun Jun 28, 2009 11:31 pm
When using 2 part 30 minute epoxy and micro-balloons as filler, what grit sanding paper works best? Is it best to wet sand?
Kyle
Nelix6030
Postby raalst » Tue Jun 30, 2009 5:06 pm
sand wet !
the dust is an irritant and goes everywhere.
wet sanding keeps the dust manageable.
a simple dust mask wouldn't hurt either.
Postby JWLaRue » Tue Jun 30, 2009 8:10 pm
Kyle,
I agree with Ronald....always wet sand. It also will give you a better sanded finish.
As for the grit to use, it depends on how much sanding you need to do. I typically start with either a 320- or 400-grit and work down to 600- and 1200-grit.
It's best if you do some practice sanding to figure out what grits work best for you.
Postby Nelix6030 » Wed Jul 01, 2009 12:19 am
ALways Great advice , Thanks
Kyle
Nelix6030
