Valterra WTC
Valterra WTC
Postby Nelix6030 » Sat Jun 20, 2009 12:41 pm
Saw a few post where people were using Valterra RV tubing for WTC. Thought I would try it since it was cheap and my scratch built end caps were always a little leaky. All I can say is WOW!. Very easy to work with, quick access in and out, and not one drop of water. Here are a few pictrures, sorry not great quality.
All I needs now is my auto leveler and it will be complete.
Kyle
Nelix6030
Postby Chuck Chesney » Sat Jun 20, 2009 1:59 pm
BRAVO...GOOD FOR YOU ! Not only better, but cheaper and readily available. Good job, and thanks for the pic's.
Chuck
Chuck Chesney
Postby xxl » Sat Jun 20, 2009 7:34 pm
looks good
Stihl 026 066
Engel lafayette
xxl
Postby junglelord » Sat Jun 20, 2009 9:42 pm
Thanks, excellent stuff. I like the learning curve of this hobby. The whole idea is to build your own WTC. Learn to mold your own parts. Very inexpensive and lots more fun.
Cheers.
junglelord
Postby redboat219 » Sun Jun 21, 2009 10:41 am
Innovative use of material 8). I see a clippard valve and a copper gas cylinder, so this means you're using a gas based ballast system. Where's your ballast tank?
redboat219
Postby Timothy Guest » Sun Jun 21, 2009 10:38 pm
Thanks for the tip. Great find. I checked out the Valterra website. Are the parts that you're using the...
T-1020-3VP: Drip Cap Set (black and orange) and
T-1022: 10" Clearview Fitting, 3"Bay Hooks x 3" Bay Lugs
I noticed that only one end of the WTC (with the orange cap) has a seal. On the other end, is there a seal inside the black cap?
--- tg ---
Timothy Guest
You got it
Postby Nelix6030 » Tue Jun 23, 2009 11:12 pm
Thats the parts, yes on the side with the four lugs The seal is in the black cap. I roughed up the inside of the black cap and then poured some liquid plastic in to thicken up the cap, but be sure not to get any on the seal.
Kyle
Nelix6030
Postby Bob the Builder » Wed Jun 24, 2009 10:57 am
I just tested my own Valterra-based WTC last night in the pool (no power, but lots of time at the bottom of 6' of water.
Not a drop after about 30 minutes of my son bumping it around at the bottom! Additionally (through no planning of my own), the WTC turned out to be almost perfectly neutrally buoyant with the tank flooded! That will make my trimming a breeze! The big ballast tank offers tons of buoyancy!
I'm really impressed with this system. Getting the WTC out of the model and getting it open to work on takes (with no exaggeration) ten seconds!
I'll have video posted of the model working (hopefully this weekend).
Great Stuff!!!
Postby Nelix6030 » Wed Jun 24, 2009 10:07 pm
Bob, WTC looks great, looking forward to the video
Kyle
Nelix6030
Postby redboat219 » Thu Jun 25, 2009 12:20 pm
What sub are you using with the WTC?
redboat219
Postby roedj » Thu Jun 25, 2009 1:33 pm
Bob,
I would be very interested in seeing how you attached the Valterra tube to the larger diameter tube (PVC?) at the right side of your picture.
Thanks for your time,
Dan
roedj
Postby Bob the Builder » Thu Jun 25, 2009 3:15 pm
I thought I had more pictures, but I guess not. Here's one more, not that you can see much of it...
For connecting to the ballast tank, I just used two pieces of 1/4" Sintra board (black plastic board) laminated together. The one side fits into the ID of the clear tubing, The other is about 1/2" larger than the OD of the clear tube. When you press it into the end of the clear tubing, you wind up with a 1/2" flange that you can bolt your ballast tank to. Its siliconed on permanently (unless you really need to take it off). A few screws put into the OD of the tube and into the endcap would make sure that they never come off, but I really think its overkill.
Here is the ballast actuator:
What Sub?
Postby Nelix6030 » Fri Jun 26, 2009 4:27 pm
Red,
My Valterra WTC is in my SubTech Albacore.
Kyle
Nelix6030
Postby roedj » Sat Jun 27, 2009 12:44 pm
Bob,
Thanks for the info and pix - nice job!
Dan
roedj
Users browsing this forum: Majestic-12 [Bot]
