It needs to be black!
Postby Ramius-II » Tue May 19, 2009 12:39 pm
Hi All!
I am not sure if here is the best place to ask this or if it belongs on a different board. I need to coat the inside of a 3mm brass tube with as flat a black as possible. I have tried paint, a chemical etchant and nothing seems to work! Paint ends up being too thick and will scrape of easily, the etchant seems to form a "powder" that easily rubs off and becomes airborne. Plating seems the next logical choice and I have no idea what material to use as a black source for the process, plus I ahve never done any plating! Any ideas or suggestions?
Thanks, Ed
Postby chips » Tue May 19, 2009 12:54 pm
Try one of the Caswell Plug-n-Plate kits, they have a black chrome kit. The kist include a power supply, solution, and gear to do simple plating jobs. In your case, I'd dip plate the tube; connect the alligator clip to the tube, immerse it in a conatiner of solution, and immerse the wand into the solution.
Bob Gesking
SC# 1575
KC8WPF
chips
Postby Ramius-II » Tue May 19, 2009 3:13 pm
Thanks! Two great ideas! I would wonder if something called "Black Chrome" would be shinny or flat finish?
Best, Ed (AKA WB6NSN)
Postby Wheelerdealer » Tue May 19, 2009 5:13 pm
Would this be for a scope :roll: ?
Wheelerdealer
Postby Ramius-II » Tue May 19, 2009 5:46 pm
Hey Ramesh!
How you been? Of course, now that the whole prescription thing is solid. I figured aluminium was too flexable and one company said they would provide the parts for $2,000.00 :shock: so now I am back to doing it myself as time allows. I may just work with the eagletree people for the rest.
Best, Ed
Postby Gerwalk » Wed May 20, 2009 5:16 pm
Electroplating won't work inside a 3mm diam. tube...unless it is just a few mm long (current lines don't flow inside a conductor, you need to place an anode inside and at that diam. it would be somethig tricky). On the other side, an electroless process can do the trick. Not sure if a black finish is available.
The guys at finishing.com have some other "solutions":
http://www.finishing.com/227/92.shtml
Pablo
Gerwalk
Postby JWLaRue » Wed May 20, 2009 10:12 pm
Perhaps a black plastic tube inserted inside the brass tube would work?
Postby aquadeep » Thu May 21, 2009 12:49 am
Perhaps "gun black" used on firearms,its to go on steel and blacks the steal and is very duable a molecular conditionig not realy a coating.
Gun smith have it,just a guess aplication.
Dave
President Roosevelt
Dave Amur Ship Yard
aquadeep
Postby Ramius-II » Thu May 21, 2009 2:01 pm
Thanks Guys,
Some really great ideas! Anodizing presents the problem of being able to anodize inside the tube as it is a reverse electroplating process where you draw material from the brass to lead and would be perfect if it were possible. The chemical processes such as gun blacking are subject to "out-gassing" that is the coating continues to produce a gas which will coat the surfaces of the lenses. A black plastic tube is a great idea and I have not found a tube material that you can use adhesives on as most are a derivitive of teflon plus the edges of the tube where the lenses are located must also be black to avoid a phenomenon called "flairing" (trails of light and color off the primary object). I certainly appreciate all the support and wonderful suggestions.
Best, Ed
Postby chips » Thu May 21, 2009 4:25 pm
The Caswell kits have an optional fine point detailing wand that allows you to plate inside a tube for a distance of about 1/8". I've plated the inside a 1/4" tube about 1/8" for an exhaust on a boat model.
Bob Gesking
SC# 1575
KC8WPF
chips
Postby Ramius-II » Thu May 21, 2009 4:47 pm
Thanks Bob and I am trying to go about 3.5"
Best, Ed
Postby aquadeep » Thu May 21, 2009 5:38 pm
Try perhaps a metal working shop that does custom work,they might have some ideas.
Even an opticle equipment maker or that type of enginners might help.
Dave :D
President Roosevelt
Dave Amur Ship Yard
aquadeep
