RFI Cap Question
RFI Cap Question
Postby Kwakelee » Fri Apr 17, 2009 8:19 am
I have a 550 series motor going in to my Scale Ships Akula and was wondering what value , and type, of suppression capacitors I should use.
Kwakelee
Postby wingtip » Fri Apr 17, 2009 9:45 am
1000 pf capacitors should help alleviate RFI from motor noise. This is what i have on my speed 500
http://www.indyhelis.com/junk/sub/gearbox002.jpg
http://www.indyhelis.com/junk/sub/gearbox005.jpg
"Nothing screams poor craftsmanship like wrinkles in your ductape!"
Dave "wingtip" Townsend
SubCommittee #2777
Martinsville Indiana
davet@insightbb.com
wingtip
Postby Ramius-II » Mon Apr 20, 2009 12:46 pm
Hi Dave!
The secret is to use 3 each 1000 pf or .1mfd capacitors in a "triangle" configuration where there ua a "cap" from each terminal to the frame of the motor and a cap from terminal to terminal. Most motors require you to file off the coating on the motor frame so the frame will accept solder. It is necessary and required to connect a heavy "ground" wire from the motor frame to the negative connection on the main battery. Each cap will take the noise generated by the motor and "conduct" the noise to the frame and the frame will have noise on it from the motor brushes. Therefore the only way the noise can be elimated is by giving the noise to the battery. The battery will act as a "filter" and prevent noise from entering the rest of your electronics.
Best, Ed
