RCABS - WTC connections to the bag?
Postby Slats » Sun Apr 12, 2009 6:17 am
Was wondering what connection you use btw the WTC end cap and the tube running to the bag? Size? Type? Etc?
J
John Slater
Sydney, Australia
Slats
Postby raalst » Sun Apr 12, 2009 7:45 am
since rcabs is only a concept : whatever you see fit to use.
let us know the results.
Postby Slats » Sun Apr 12, 2009 8:20 am
raalst wrote:since rcabs is only a concept : whatever you see fit to use.
Why is it only a concept? Many people use it.
Was wondering therefore what people who generally use those rubber bags use to attach the rubber hose from the bag to the WTC end cap?
J
John Slater
Sydney, Australia
Slats
Postby Wayne Frey » Sun Apr 12, 2009 9:04 am
John,
If I understand you correctly, I am using a simple copper tube section with the wtc cap about the halfway point. Tube simply slides over it, inside and outside.
Thats it. Simple. Not complicated. No secrets. Straightforward as heck.
Postby Slats » Sun Apr 12, 2009 9:13 am
Thanks Wayne
J
John Slater
Sydney, Australia
Slats
Postby Art Broder » Sun Apr 12, 2009 9:40 am
I use whatever size brass tubing fits snugly into the bladder hose. The bladder hose size usually varies according to the brand. The brass tube is cemented with CA into a hole made through the end cap. Friction fit of the bladder hose on the brass tubing, without clamps, is sufficient. I usually use airplane silicone fuel line to make connections inside the watertight compartment, to save space.
Art Broder
SubCommittee#0060
Art Broder
Postby Lobo » Sun Apr 12, 2009 11:54 am
Wayne Frey wrote:John,
Yeppers on that, but I do use tee's on occasion....
since I am using a single hose bladder on one application, I do have a nylon automotive vaccuum tee in that setup. Aquarium/Fish tank tee's are also good to use if a tee is needed. I keep both on hand in case needed.
Lobo
Postby wingtip » Wed Apr 15, 2009 3:42 pm
"Nothing screams poor craftsmanship like wrinkles in your ductape!"
Dave "wingtip" Townsend
SubCommittee #2777
Martinsville Indiana
davet@insightbb.com
wingtip
rcabs
Postby clive » Thu Apr 16, 2009 9:05 am
raalst wrote:since rcabs is only a concept.
Show my ignorance on terminolgy :( What is RCABS? :oops:
clive
Postby Art Broder » Thu Apr 16, 2009 9:29 am
RCABS is an acronym for the Recirculating Compressed Air Ballast System.
For details, see my site, http://artbrodersmodels.multiply.com/ and scroll down to Links, then choose any RCABS link.
Art Broder
SubCommittee#0060
Art Broder
Postby fgroza » Tue Apr 21, 2009 9:00 am
I use 1/8" brass tubing with DuBro barbs soldered on the end to prevent the tube from coming off.
Frank
fgroza
Postby raalst » Tue Apr 21, 2009 3:47 pm
@wingtip : please check your email address (what you filled in in the profile)
your email bounces. you switched on notifications and these do not reach you currently
