RCABS Question
Postby kazzer » Tue Mar 17, 2009 11:08 pm
post deleted
kazzer
Postby expfcwintergreen » Wed Mar 18, 2009 6:11 am
kazzer wrote:
expfcwintergreen wrote:Actually, the platform is well off to one side (near the heads).
Regardless, the boat was deeper than I would typically run and my RCABS worked flawlessly with zero leaks.
Did I mention how cheap and easy it was to put together? :D
Good grief!
My sentiments exactly!
XOXO
expfcwintergreen
Postby Rogue Sub » Wed Mar 18, 2009 2:16 pm
Tisk tisk making threats with a caged monkey. Ofcourse there was a monkey that got loose up here and did some damage to a woman. Maybe Ill tie a bannana around your neck first!
Kevin
A Global Force For Good
http://WWW.ROGUESUBWORKS.COM
Rogue Sub
Postby Skip Asay » Wed Mar 18, 2009 2:54 pm
OK. I’m quite sure this horse is dead so I guess it’s time to stop flogging it. The bottom line is that there are a variety of different types of ballast systems and the use of each is determined by the guy who’s building/using it. Each has its good points as well as bad points. It’s all a matter of personal preference. Let’s face it, some guys love Fords, some guys love Chevrolets. And some guys love teardrop shaped boats and others love WWII boats. And never the twain shall meet. Get over it.
Now, can we get back to doing whatever it was we were doing?
Skip Asay
The U.S. of A - Land of the Free BECAUSE of the Brave
Skip Asay
Postby Pirate » Sat Mar 21, 2009 9:36 pm
I like the talk so much that you make enough hot air to raise anything ballast system. So I guess that this forum would work just fine. Just stick it in your boat and go.
HOLD FAST
Pirate
Previous
