Missile Construction Question
Postby Rogue Sub » Wed Jan 14, 2009 11:04 pm
The copper endcaps are hollow with the exception of the pin, gas inlet chamber and smaller Dia copper tube thats used to fit it to the main body. The bottom cups are held in the main tubes by friction. All I did was give the tubes a small smack with a hammer and it indented them enough to hold the tube in place ( an old plumbers trick).
Kevin
A Global Force For Good
http://WWW.ROGUESUBWORKS.COM
Rogue Sub
Postby Ramius-II » Thu Jan 15, 2009 1:15 am
Interesting! When I get a little further along I'll take some pictures. Right now I am correcting an oops! :lol:
Best, Ed
Just one more wire!
SC# 2268
WB6NSN
Ramius-II
Postby Rogue Sub » Thu Jan 15, 2009 4:25 pm
Yeah I am getting a rash of rain on the SP site for using PVC missiles.. and a dash of salt for making missiles at all.... It would seem that PVC=grenade...
Kevin
Rogue Sub
Postby Ramius-II » Thu Jan 15, 2009 4:44 pm
I understand and it could be much worse! People know I am building a sub in my garage, have travelled to Russia many times and have many Russian friends, and a US military friend offered a subminiture guidance system. I came home one day and was greeted by a man from the FBI! Totally unrelated matter and still ...... :lol:
Ed
Just one more wire!
SC# 2268
WB6NSN
Ramius-II
Postby Rogue Sub » Thu Jan 15, 2009 4:56 pm
Ill notify NCIS about you just for good measure.
Kevin
Rogue Sub
Postby expfcwintergreen » Thu Jan 15, 2009 5:06 pm
Nuke Power wrote: It would seem that PVC=grenade...
Dude... you don't listen to me. That's the problem.... :D
expfcwintergreen
Postby Rogue Sub » Thu Jan 15, 2009 6:31 pm
Chris dont think I didnt hear you...I am just getting attacked from a few people now.
Kevin
Rogue Sub
Postby expfcwintergreen » Thu Jan 15, 2009 6:37 pm
Didn't you see my smiley??
I may have some material to help you out, we can go over it on Saturday. Can you e-mail me the tube dimensions again (just OD and length)?
expfcwintergreen
Postby Rogue Sub » Thu Jan 15, 2009 6:45 pm
Ok but look out when you get here. I have replaced all the claymores with propel filled missiles and my guard tony will bite your legs off.
Kevin
Rogue Sub
Postby Ramius-II » Fri Jan 16, 2009 11:11 am
Another question!
I noticed there is a pressure storage assembly with a schader valve and two small tubes at one end. My guess is that each of the small tubes feeds pressure to each of your two missile launch end cap. If you fired only one missile, would you not completely drain the launch pressure you have stored or is there some method to "pulse" the pressure feed?
Just one more wire!
SC# 2268
WB6NSN
Ramius-II
Postby Rogue Sub » Fri Jan 16, 2009 2:57 pm
The plan is to install a valve in each line so that once I see the missile leave the tube I can secure the launch gas. Only testing will tell me if the chmber i have made is large enough.
Kevin
Rogue Sub
Postby Rogue Sub » Sat Jan 17, 2009 8:54 pm
Looks like it is time to get some aluminum tubing from mcmaster carr.
Kevin
Rogue Sub
Previous
