articals on torpedo system
Postby clarkkent » Sun Nov 16, 2008 9:51 pm
i heard there were a few articals on torpedo systems could anyone direct me to a website perferably the one by dave merriman of mike dory
you have to be smarter than a watermelon before you can eat it
clarkkent
Torpedo INFO
Postby Theo » Sun Nov 16, 2008 11:03 pm
You can find several articles on Torpedo's in the R/C Modeler Forum and I have developed a torpedo that goes about 35-40' for my 1/72 scale Gato. What INFO are you looking for??
Jack
Theo
Torpedoes
Postby Mike Dory » Mon Nov 17, 2008 12:38 pm
Howdy - I have had some experence with working torpedoes. As Jack said, What are you looking for? We maybe able to help you. . Our Best Wishes...Mike Dory
Mike Dory
Postby RickNelson » Mon Nov 17, 2008 6:55 pm
I would like to build a torpedo system and torpedos for my 1/72 Gato. Would you have any pictures or documents available?
TIA
Rick Nelson
Qualified in Submarines 1965
SCM #2583
"Boomers hide with Pride"
RickNelson
Postby Scott T » Tue Nov 18, 2008 12:25 pm
Torpedo's for a 1/72 scale Gato
Postby Theo » Tue Nov 18, 2008 2:41 pm
I am somewhat new at the sub building game, but have many ideas!! As I have built a 1/72 scale Gato as well as the ability to launch 4 torpedoe's, here are my thoughts for the 1/72 scale Gato.
1) The torpedo system must be light (weight) so as not to screw up the dynamic balance of the sub and make it somewhat Bow heavy.
2) The torpedo should be light enough to float when the gas is expended.
3) The torpedo should also be dynamically balanced so that it will go "true" in the water as well as being able to travel a respectful distance.
I used 3/64 x .006 Brass tubing for the torpedo exhaust tube that extends to near the fill valve. The reason is so that the torpedo will travel about 35' to 40 '.
The Torpedo fill valve is a modified car valve inserted (screwed) into a machined plastic rod that has an O-ring as a gas seal.
The tail section of the torpedo is a molded plastic section with fins & O-ring seal that spin the torpedo in the water.
The launch tube is extended with torpedo inserted into launch tube some distance out from the Bow of the sub when filling the torpedo with propellant. Then retracted into sub when ready to launch the Gato.
I modified my R/C transmitter to have a push button On/Off switch that sends a signal to a 8 bit shift register that will fire the torpedo's. Position "0" in the start position of the shift register, position 1-4 are the firing positions for each torpedo and position 5 is the reset position for the shift register. The shift register triggers the 4 control valves via a power optical coupler, one torpedo at a time with each press of the transmitter launch switch.
I have attached some pictures and I will be happy to answer any questions you might have.
Jack
Theo
