Lead free weights
Postby expfcwintergreen » Sun Aug 31, 2008 5:05 pm
Tungsten isn't dangerous. It is an effective lead substitute because of the density. It was also used as a substitute for DU penetrators (again.... "green" ammunition) due to its density. Not as effective as DU (less density and no pyroforic properties), but it gives people a warm fuzzy feeling that we are protecting the environment while destroying tanks.
They also make wedding bands out of Tungsten.
I use lead because it works, is cheap and as Tim said not that bad on the environment or your health. Just dont eat it (ironically, that's what we used to say when we were working with DU....).
expfcwintergreen
Postby petn7 » Sun Aug 31, 2008 5:30 pm
I would like to avoid using lead, except when soldering.
If I can avoid having the lead contact the water or touch my skin (and forcing me to wash my hands), all the better. Probably wouldn't hurt to remove reasons for someone to not let you use their pool. Granted, this has never been an excuse when I asked, but if I can use zinc, nickel, brass, or tungsten, why not?
petn7
Postby petn7 » Sun Aug 31, 2008 5:33 pm
expfcwintergreen wrote:Tungsten isn't dangerous. It is an effective lead substitute because of the density. It was also used as a substitute for DU penetrators (again.... "green" ammunition) due to its density. Not as effective as DU (less density and no pyroforic properties), but it gives people a warm fuzzy feeling that we are protecting the environment while destroying tanks.
Which makes me wonder...
What would be more pretentious: using $160, digital, brushless servos, OR using platinum ballast weights? :lol:
petn7
Postby Rogue Sub » Sun Aug 31, 2008 6:50 pm
Yeah I was speaking of thoriated tungsten. It is still a very low level emiter though. You have a higher risk from sitting in the sun for an hour.
Postby hakkikt » Mon Sep 01, 2008 7:58 am
Gold would be even more suitable. It is very inert and much heavier than lead. It is also a good way of reflecting certain post-war legends in your model if you use it as ballast in a U-boat. :D
- mobilis in mobili -
SC#1604
hakkikt
Postby Boss subfixer » Tue Sep 02, 2008 4:13 pm
Here is one thing that no one touched on about when using lead. If you paint it with several coats you will have no worries as to washing your hands, leaching or any of the other nasty problems you can have with lead. Plasti dip is even better. As Tim pointed out don't breath the fumes when heating it, also if it has a white powder on it that's oxidation you don't want to breath that either. That's bad as well. It's not a bad thing to not want to use lead but it can be handled safely when properly sealed.
Don Evans
SCM# 2733
Boss subfixer
Postby petn7 » Tue Sep 02, 2008 6:00 pm
It's too much trouble to plastidip or paint every single piece of lead. I thought about encasing the pieces of lead in epoxy or JB WELD (to the hull), but should I install a new WTC and need to re-trim, there might be a problem.
petn7
Postby Boss subfixer » Tue Sep 02, 2008 7:25 pm
I hear you. My reply was more for others that are reading this just to give them options and a little more information. As I said there is nothing wrong with going lead free. My hats off to you.
Don Evans
SCM# 2733
Boss subfixer
Postby kazzer » Mon Nov 24, 2008 11:26 pm
We have developed several sets of weights which are made of lead shot encapsulated in epoxy resin. These are molded to the shape of the hull.
If you don't see your model here, please let us know and we'll make a a specific set to suit.
http://www.caswellplating.com/models/weights.html
A strip of lead sheet is enclosed with each set of molded weights, to 'fine tune' the model. This should resolve all your lead problems.
Coming soon. Molded ballast FOAM insert to suit the Revell models.
kazzer
