Lead free weights
Lead free weights
Postby petn7 » Wed Aug 27, 2008 11:47 pm
Seems like lead free substitutes involve zinc or steel, with the latter not being useful because of corrosion. However, what about nickel plated brass? Those Wal-Mart Subworks submarines came with lead free weights that I believe are pieces of brass coated with nickel or maybe chrome. Does anybody know where to buy these? I would like to avoid using lead and I'm pretty sure I'll have enough space to avoid using denser, but more dangerous lead.
These seem to be a promising possibility
http://www3.towerhobbies.com/cgi-bin/wt ... XDH63&P=ML
petn7
Postby DavieTait » Thu Aug 28, 2008 6:35 am
There are lead free angling split shot weights ( from the size of a grain of rice up to BB size ) available over here that could be used to glue into the bilge of a model petn7. Been available over here for 22 years since they banned the use of lead angling weights on freshwater fisheries ( lead weights get eaten by Swans/Ducks/etc and its a pretty nasty way for them to die.. )
http://www.non-toxic-fishing-weights.co ... cturer.htm
DavieTait
Postby petn7 » Thu Aug 28, 2008 12:58 pm
The weights from the tower hobbies website are made of zinc, nickel, and tin, in case you guys are curious. It looks like that's what I'll get unless you guys have other lead-free suggestions.
petn7
Postby Sub culture » Thu Aug 28, 2008 1:31 pm
If you can get hold of any chunks of tungsten, that is very dense stuff- almost twice the weight per volume of lead.
Postby petn7 » Thu Aug 28, 2008 2:07 pm
Sub culture wrote:If you can get hold of any chunks of tungsten, that is very dense stuff- almost twice the weight per volume of lead.
Interesting. How expensive is that stuff?
petn7
Postby expfcwintergreen » Thu Aug 28, 2008 2:27 pm
McMaster-Carr sells it.
Good luck cutting it to size.... :shock:
expfcwintergreen
Postby redboat219 » Fri Aug 29, 2008 2:24 am
How about using discarded tungsten carbide machine tools :D
redboat219
Postby petn7 » Fri Aug 29, 2008 8:17 am
redboat219 wrote:How about using discarded tungsten carbide machine tools :D
I don't have any.
petn7
Postby Rogue Sub » Fri Aug 29, 2008 11:29 am
tungsten welding probes, its brittle stuf so you can break it with enough force. Grinding is a challenge, cutting..forget it. And if you get thoriated tungsten it will be radioactive like the real boats!
If your bored you can melt pennies or just glue nickels in there. Ive used money to trim at the pond before.
Postby redboat219 » Fri Aug 29, 2008 12:02 pm
Nuke Power wrote:tungsten welding probes, its brittle stuf so you can break it with enough force. Grinding is a challenge, cutting..forget it. And if you get thoriated tungsten it will be radioactive like the real boats!
WOW :shock:
Maybe we can use it to fuel a pico nuclear reactor instead :lol: :lol: :lol:
You can run yours sub for years. 8)
redboat219
Postby Rogue Sub » Fri Aug 29, 2008 3:36 pm
That would be a cool thing but would probably take way to much room to convert the energy to power. Not to mention those things are gamma emitters (i believe) and we would be after neutrons. Oh and their radiation levels are just a little higher then you would get from a banana!
Postby Polaris » Fri Aug 29, 2008 4:26 pm
Guys, Tungsten is avalible in shot form, I use it in my turkey loads. It first came on the scene in the hunting world as hevi-shot, and has since become aval from several shot load manufacturers. Check out your local reloading supply store or search it on the web. Here is a website I found through Google,
http://www.tungsten-spheres.com/tungsten_shot.html
http://www.hevishot.com/home.html
It can be expensive to buy in bulk ( 150$ for a 7lb bag) :shock: but depending on how much weight you need just buy a box of Hevi-Shot shells and remove the shot. And make your own fireworks with the powder and primer charge. :P
regards,
Stuart
Polaris
Postby petn7 » Fri Aug 29, 2008 6:59 pm
Sounds dangerous, Polaris.
I already ordered those nickel, tin, and zinc weights. Maybe I'll try tungsten next time I build a submarine. Sounds like a great thing for small subs where space is limited.
petn7
Postby redboat219 » Sun Aug 31, 2008 12:31 pm
Nuke Power wrote: Not to mention those things are gamma emitters
OMG! :shock:
RAGH!!! Hulk smash!!!!
:lol: :lol: :lol:
redboat219
Postby TMSmalley » Sun Aug 31, 2008 4:28 pm
What are your reasons for not wanting to use lead?
It doesn't leach into the water unless you leave your boat in the water for a few dozn years. The main reason it is used in bird shot is due to water birds picking it up and grinding it up in their gizards and injuring the birds or killing raptors (eagles, hawks, owls, etc. ) that may kill them. With the little bit we use, unless you breathe the fumes, it while melting it, or eat a bunch of it, the effect is non-existant.
