Changing stock WTC on Engel Typhoon - Into cylinder WTC any advice?
Postby 115-1075226400 » Mon Feb 23, 2004 7:33 am
Hi Im going to equip my newly bought Engel typhoon with cylinder WTC instead of the stock WTC from engel.
I have never seen a real WTC and wonder which parts goes where and what needs to be in the WTC.
As for materials Im thinking of using PVC that is visible.
How thick should it be?how do I put it all in the WTC and keep it steady?
also how do I get a good boyance with it? should I try to place the WTC where the original stuff was? or will I have to move it around until I get a good balance in the sub?
Grateful for all suggestions and helpful ideas
Edited By skuggan on 1077536214
115-1075226400
Postby Novagator » Mon Feb 23, 2004 10:20 am
Why would you want to do this? You would have to scrap most of the engel equipment and unless you sell it, its a waste of money. I would not go with a cylinder WTC, it would not work as well.
John Cottingham
Sub Committee Member #2721
Novagator
Postby 115-1075226400 » Mon Feb 23, 2004 2:03 pm
because I have been told that if I use the stock WTC I will not be able to mount missiles in the sub, and I would very much like to build a 2 tube system.
Is there another way or perhaps even possible to do it, then Im all open :;):
115-1075226400
Postby Novagator » Mon Feb 23, 2004 2:21 pm
Why not section off a section for a missle compartment. Leave the front dive planes static, and fashion up something. Bo@ti is trying to do the same thing.
http://home.no.net/boati/index.htm
John Cottingham
Novagator
Postby 115-1075226400 » Mon Feb 23, 2004 2:32 pm
Will it work then?
Im not sure what to do! this is my first sub so I dont have that much experience with what to do!
But Thierry is pretty sure that I should build my own WTC:s and put them in the sub
115-1075226400
Postby Novagator » Mon Feb 23, 2004 2:45 pm
skuggan wrote:Will it work then?
How set are you on missles? I would not do that for a first sub, but what do I know. But if Thiery says no, then go with him. :p
I seriously considered getting the engel typhoon for my first sub, but I wanted to use it sometime in the future.
So you want to do this
John Cottingham
Novagator
Postby Novagator » Mon Feb 23, 2004 2:46 pm
John Cottingham
Novagator
Postby Novagator » Mon Feb 23, 2004 2:47 pm
John Cottingham
Novagator
Postby 115-1075226400 » Mon Feb 23, 2004 2:51 pm
Yeah or at least something like that =)
115-1075226400
Postby ThierryC » Mon Feb 23, 2004 2:57 pm
I basically told him to go with something similar to this:
(Forgive the quality of the drawing, my drawing skills are not the best :D )
Sub-Systems
ThierryC
Postby bo@ti » Mon Feb 23, 2004 3:09 pm
Hold them horses :p
Skuggan, depending on youre previews modeling skills. The only modification I would do for the Engel Typhoon are "Improved Lexan lid".
Or
There are room in the Engel Typhoon for an PVC tube of about 140mm OD.
They do not make PVC clear though, so u'll have to use Lexan or more comon used Acryl.
Im still fiddling with my Missiles :D
bo@ti
Postby 115-1075226400 » Mon Feb 23, 2004 4:26 pm
Hi bo@ti :)
hehehe well my earlier experiences only looks at my Serpent RC car, how is it going in the development of your missiles then? Im not going to use propel gas so I dont need a launcher I only need 2 tubes that go completly thru the hull.
But Thierry says that there is no way to find the space needed inside the hull, have you found anything to prove him wrong? It would make me a very happy puppy if there is a possibility to use the stock WTC so that I don't have to spend alot of time creating my own WTC:s as I plan to have this sub going this year, not 2010 :D
And there is clear PVC pipes we use them at work :)
Edited By skuggan on 1077568054
115-1075226400
Postby bo@ti » Mon Feb 23, 2004 4:44 pm
Hi, I just knew I had to be eaten the words: "There are no Clear PVC" :D
But no I dont think there are room for 20 missiles, anyway you make them or the WTC.
Why should they go thru the hull?
Im more on to Estes "Fireworks" right now. But haven't desided anyway around :laugh:
bo@ti
Postby 115-1075226400 » Mon Feb 23, 2004 4:46 pm
hahahaha :)
no no no not 20 I said 2 :) hahahaha no I don't think I can afford 20 missiles at a cost of 900$ each :)
I think that would be the death of me :)
But two could I fit two in?
Not thru thru but They need to go all the way to the bottom and have a aluminium plate to stand on! because there is a risk that the missiles from Estes will burn down your sub otherwise I to will use Estes as a startrocket
Edited By skuggan on 1077569293
115-1075226400
Postby Novagator » Mon Feb 23, 2004 4:49 pm
skuggan wrote:hahahaha :)
$900 for model rockets? What kind of rockets are you using?
John Cottingham
Novagator
