Stainless Steal Shafts - Where to buy
Postby MIT » Fri Jan 09, 2004 5:51 pm
Where is a good place to buy Stainless steal shafts ?
I am looking for 3/16 diameter so that it will match up with Skips's Shaft seal tubes .
Nick
MIT
Postby JWLaRue » Fri Jan 09, 2004 9:56 pm
Hi Nick,
If you are looking for shafts that have one end threaded, I'd recommend Ships n' Things (www.alsnt.com).
If you're going to do the threading, go to McMaster-Carr (www.mcmaster.com).
Postby ThorDesign » Fri Jan 09, 2004 10:00 pm
I have precision ground stainless shafts in stock in 3/16" O.D. You may view them on the hardware page at www.thordesign.com
ThorDesign
Postby MIT » Sun Jan 11, 2004 9:34 pm
Thanks for the input folks !
MIT
Postby Dolphin » Sun Jan 11, 2004 10:59 pm
Does anyone also know of a source for stainless steel (threaded or unthreaded) 3 mm. diameter shafts too? These would fit through the ball bearing supports of a sub I am designing/building.
Thank you,
Steve Reichmuth
Dolphin
Postby ThorDesign » Sun Jan 11, 2004 11:02 pm
Steve,
I can get the 3mm shaft for you in any length up to 48", but I will have to special order it for you.
ThorDesign
