Explorer submarine... - Explores (TV, robot hands) underwater
Postby mountains19 » Thu Aug 28, 2003 2:27 am
Dear folks,
Hi! I am thinking about making a R/C submarine that will explore underwater stuff, like bottoms of bays, etc. It will use a TV camera (and maybe a cable for the camera), robotic arms that can pick up objects, and its design will be totally different from a regular submarine.
It will not look like a nuclear sub, but probably more like the sub Alvin, or a saucer shape.
It will dive to a maximum depth of 100 feet, so it will have to be made of pressure-resistant material, and have a good pressure-resistant shape.
It will be no larger than 3 feet in any dimension.
Can anyone help me?
Thanks! :;):
mountains19
Postby KOEZE » Thu Aug 28, 2003 3:00 am
R/c might be a problem as the signal only penetrates about 6 feet in best water conditions. You might wnat to consider an umbilical cord for commands and feedback.
Another option would be the use of acoustic signals to give the sub it's commands. If you then use an onboard means of storage for the video you can skip the cables all together.
Just a few initial thoughts
EJK
You don't stop playing because you get older,
you get older because you stop playing.
KOEZE
Postby MB1754 » Fri Aug 29, 2003 10:26 pm
You might want to purchase the book: "BUILD YOUR OWN UNDERWATER ROBOT AND OTHER WET PROJECTS" by Bohm and Jensen. You can get a copy from "Harbor Branch" florida(they have a Yahoo! store online). :)
MB1754
Postby Seahawk » Mon Sep 01, 2003 3:36 pm
I bought a copy of the "Build your own Underwater Robot" book a couple weeks ago. I'll have to build one of them soon. They have plans for two different ROVs in the book. Very nice for getting the basics of ROVing. Tim Smalley has built one of the designs and modified it to carry a camera, he has pictures of it on his website
SubCommittee #2508
Seahawk
Postby Wayne Frey » Thu Sep 04, 2003 6:16 am
I am building one of the ROV projects on that link.It should be ready for the SubRon 5 run for next year so we can get video images of the boats on manuvers.They do not have ANY lift abilities,as they are rigged to be neutrally bouyant.I am thinking maybe another release-type tether attached to a snare,claw,or something to retrive treasures or maybe a jennifer-project kind of recovery of a stray submarine.But simplicity is paramount.
I have the frame together,with "T" fittings at the lower front of the frame so I can add the attachment rig later.
It happens that Supercircuits,which offers a free catalog full of way-cool small cameras,is only 45 minutes from my house.In the near future,I am going up there to get a camera rig,and to talk to them about rigs for the ROV and possiblities for periscope and sail mounted cameras.They offer underwater cameras right now that could be adapted we to the ROV.
One more thing I will add will be some kind of lights just behind the camera for murky or dark water.
It is not a hard,or expensive project.
Wayne
SCM #653
SubCommittee Vice President 2006-2008
Author-Russian Submarines, Guardians of the Motherland
Member-Saint Petersburg Russia Submarine Club
Wayne Frey
Postby TMSmalley » Thu Sep 04, 2003 8:54 am
I have been trying to get the umbilical so it is as close to neutral bouyancy as possible. This is important because the ROV is trimmed so it just barely floats at the surface. Otherwise you have to keep the down thruster activated all the time.
I tried fishing bobbers on the cable but they are a little too expensive so I am now trying foam pipe insulation.
Tim Smalley
TMSmalley
Postby Wayne Frey » Wed Sep 10, 2003 9:39 pm
Tim,
Yours is a working model.What do you think about mounting some kind of small lights? In you experiance,is it worth it maybe?Could be a good excuse to get a girl out to the water at night.....
SCM #653
Wayne Frey
Postby TMSmalley » Thu Sep 11, 2003 6:50 am
I haven't tried taking it out at night. I have a hard enough time keeping track of all the wires and adapters, etc. in broad daylight. :p
However I used to do some night time scuba diving u/w photography and learned that if you do use lights on your camera, be sure to put them on arms out and at an angle in. It will cut down on the amount of backscatter you get from turbidity.
Tim Smalley
TMSmalley
Postby Wayne Frey » Mon Sep 15, 2003 6:47 am
Good idea on the lights.I will figure that in as well.
Now,how to build a claw or retrival system.Since the ROV cannot lift.A claw.hook,or snare would have to be detacable so one could reel up the treasure(or downed sub)on a diffrent line.There are lots of heavy rated fishing line out there that could work.
Any ideas?
SCM #653
Wayne Frey
