Engel Static Depth Controller - I do not understand
Postby Rockpile » Thu Jul 03, 2003 12:33 pm
Jaut received the TAES Static Depth Controller upgrade kit from ENGEL.
I am useing the robbe Futabe FC-16 radio System in my 1/32 Fleet Boat and 1/32 Tyoe IX. I have the TAE pistons tanks installed and operating properly in the boats. Execlant trim and submerged running.
I wish to install the (Static Depth Controller) in both boats. Reading the instlation instructions for the unit into the boat is understood.
I do not understand the transmitter setup. As per instructions,
(" The TAES processes four different commands which must be directed individually. Therefore, it is advisable to control the TASE via a proportional shifter on the transmitter").
PLEASE What is a PRORTIONAL SHIFTER )?
I am not able to find any information in the robbe Futaba system Manual.
My system is set up with Twin stick , a Multi-Prop Modul/ Multi-Prop Decoder , Multi-Switch Modul / Multi-Switch Decoder. (2) two Linear poportional channels.
Any help would be greatly appreciated.
Keep It Fun
(RIGHT)
Patience my ### I'm gonna kill Something.
Rockpile
Postby jlemons » Thu Jul 03, 2003 12:59 pm
It's a linear proportional slide. You can purchase this from Robbe. The part number is f1501.
Edited By jlemons on 1057255264
James Lemons
Fort Worth Texas
You are correct Captian, I see them. On our right as well as our left. Sensors indicate them to be.....................gray hair.
jlemons
Postby Rockpile » Thu Jul 03, 2003 3:31 pm
Thanks James,
I have 2 of those installed in the transmitter.
part # 1601 ?
they are set up now to have the center off. Is this correct?
Thanks for the help.
Jack
Keep It Fun
(RIGHT)
Rockpile
Postby jlemons » Thu Jul 03, 2003 4:05 pm
The way mine is setup. All the way forward is full dive, 3/4 is hover, 1/4 is stop dive, all the way back is surface.
James Lemons
Fort Worth Texas
jlemons
Postby Ramius-II » Thu Jul 03, 2003 6:14 pm
Hi Jack & James:
The 1601 is the latest version of the 1501. The 1601 has extra components to increase reliability. I had the same question and asked Robbe.
Ed :)
Postby Rockpile » Thu Jul 03, 2003 7:46 pm
Looks like the answer that I needed. Thank you all for the help :D
Keep It Fun
(RIGHT)
Rockpile
