new krick type Vllb - kit contents
Postby boatbuilder1 » Sat Mar 15, 2003 12:07 pm
I received my kit yesterday thanks ward
I have to say it is much smaller than I thought probably due to all the robbe kits I build. it arrived with a hole in the outer and inner box postal monkeys! :angry:
lots of stuff in there but the box weighs less than20 pounds
the hull is vacmolded in half split down the middle vertivcally from bow to stern,the decks are quite dissapointing ??? they ment well but fell well short of the goal they are vacmolded very thin styrene and all those flood holes need to be cut open or drilled with a .001 bit yuck cut them open and sand off the excess off the back much easyer
the tower and acompaning parts are all vac molded turdy even more so than the robbe stuff nice.the boat has a vacmolded ballast tank that sits on top of the pressure hull .
the latter being quite roomy if you think through your arrangment of gear and toss out the plan inlcuded with the kit
they suggest only 2 servos ,1 for bow planes ,1 for rudder WHAT NO STERN PLANES? ??? there is room in there if you use mini servos or one small gell cell and not the 2 nicad packs suggested ouch no run time at all and talk about heat WOW :(
making the stern planes operational will be a challenge but definately doable. there are lots of cast metal deck fittings nicely done and all the linkage,control arms etc,etc
the hull has some strange flood pattern holes on the sides I am unaware of these on any plan or print of the original so these will be filled over
over all impresion is good its a nice small boat that can travel with you it might even fit in an overhead on the plane
I give it 3 and a half stars out of 5
ca :D check my site next week for pics
Edited By boatbuilder1 on 1047744673
charlie
its all relative
boatbuilder1
Postby smwarships » Mon Mar 17, 2003 8:06 pm
How much does Krick charge for this type VII sub ?
From your outline that you posted , it sure does not
sound like anything to invest in ??
What is your website address so I can check out the
photos of this sub ??
Darle Bennett
Scale Model WarShips ???
smwarships
Postby boatbuilder1 » Tue Mar 18, 2003 9:54 pm
399.99 is the cost at loyalhanna
http://model-construction.50megs.com/index.html
no pics yet though I was out of town for funneral look for them late this week
charlie
its all relative
boatbuilder1
Postby boatbuilder1 » Sat Mar 29, 2003 11:34 pm
have pics in now if anyone wants to see them send and email
andrsnhaus@earthlink.net
charlie
its all relative
boatbuilder1
Users browsing this forum: Ober Freak
