Basics with CO2 - Need help with Co2 system
Postby ThierryC » Tue Mar 11, 2003 6:37 pm
Hello
I might be using a CO2 system for my sub, but I have never seen or used a system like that, is there somebody who could explain to me in detail the parts needed, pressures available, etc.....
Sub-Systems
ThierryC
Postby JWLaRue » Tue Mar 11, 2003 8:07 pm
Hi Thierry,
A good person to contact would be our very own Membership Chairman, Jim Butt. He has been running CO2 in his 1/48th scale fleetboat for many years.
In case he doesn't see this, Jim can be contacted at Membership@subcommittee.com
Postby Bigdave » Wed Mar 12, 2003 9:32 am
Hi Thierry, I use CO2 in my Nautilus. The heart of my system is a regulator I purschased from Mike Shubar. If you start at the high pressure end I have a paint ball 4 ounce CO2 cylinder. These only cost me $1 to fill and last a long time. I connected the cylinder to a universal fill adapter. You can get this at your paint ball supply store. It screws on to the cylinder and my regulator is mounted to it. The regulator is connected to a clippard valve with small pressure hose. The output is about 30-40 PSI out of the regulator. The output from the valve is sent to the ballast tank with the same pressure hose. The valve is controlled by a Subtech SES2 electronic switch. In my system I also use a second clippard valve to control a spring loaded piston to vent the tank. I will send you some pictures of my system. I have no way to post them or I would include them now. I have used this system for 4 years now with no problems. I hope this helps. :O
