magnetic switches
magnetic switches
Postby P Webster » Sat Mar 15, 2014 4:35 am
Does anyone know of a supplier of magnetic reed switch and relay assemblies suitable for switching on the complete system of the sub (ie main battery and receiver battery.
I am also looking at using 3 x 2v 8amp Cyclon batteries instead of the recommended 6v 12amp SLA battery. Except for the reduced running time can anyone see any other problems this could cause?
P Webster
Re: magnetic switches
Postby KevinMc » Sat Mar 15, 2014 6:59 am
Hi,
I might have something for you. Please check your PM
KMc Designs
SC #2870
SubComOn
KevinMc
Postby Ober Freak » Sat Mar 15, 2014 3:32 pm
I use these Relays,
1 in my Seawolf and 2 in parallel in my U47, with one reed contact per coil.
Never had any problems with them.
Ober Freak
Postby Johnredearth » Wed Aug 20, 2014 5:49 pm
Get door switches off ebay. $1.50 each. Add a couple of relays and you have the perfect thing.
Johnredearth
Postby sam reichart » Wed Aug 20, 2014 7:31 pm
Don Spielberger used to build and sell them. (Loyalhanna Dockyard...)
sam reichart
Postby Pedro Gómez » Wed Sep 24, 2014 7:00 am
Engel modellbau has, and Norbert Bruggen Modellubootspezialitaten too.
Pedro Gómez
Postby Sub culture » Wed Sep 24, 2014 7:40 am
Reed switches can be found very inexpensively on ebay. You want a pair of normally open type often abbreviated to 'NO'.
For a relay, you require a bistable unit. These can be a little trickier to find, but are available. You should aim to get one with voltage coils similar to your system voltage.
If you want to switch very high currents you can have the relay contact(s) pick-up the gate of a P-channel Mosfet to switch the load, or perhaps switch the low side with an N-channel Mosfet (anyone tried that?). To switch the high side with an N-channel you would need a driver chip to raise the gate about 10 volts.
Postby Johnredearth » Thu Sep 25, 2014 5:01 pm
For relays, check these out. Fabulous build quality, very very cheap
http://www.ebay.com.au/itm/131164167875 ... 1497.l2649
I have just installed one of these with a door switich on a surface boat!
Cheers
John
Johnredearth
Postby Johnredearth » Thu Sep 25, 2014 5:07 pm
whoops I forgot I have something on this
http://youtu.be/vVN4Aen0LLk
John
Johnredearth
Postby Scott T » Fri Sep 26, 2014 1:47 pm
Nice sub video John.
