NEED 1/4" ROTARY SHAFT SEALS
Postby dhffr » Tue Feb 18, 2014 5:48 pm
Looking for the Simmering type shaft seals for a 1/4" shaft. Engel only goes to 5mm I believe. I'm thinking even 6mm would be fine since 1/4" is 6.35. Prefer the type with the retaining spring. Any info would be appreciated.
DH
dhffr
Re: NEED 1/4" ROTARY SHAFT SEALS
Postby JWLaRue » Tue Feb 18, 2014 5:55 pm
...McMaster-Carr is your friend....!
http://www.mcmaster.com
Postby dhffr » Tue Feb 18, 2014 6:04 pm
They don't have them.....
D
dhffr
Postby Sub culture » Tue Feb 18, 2014 6:09 pm
Postby dhffr » Tue Feb 18, 2014 7:40 pm
Thanks Andy. I saw this one that says it's for rotary applications. Would it be a better choice?
D
http://simplybearings.co.uk/shop/p32005 ... _info.html
dhffr
Postby Sub culture » Wed Feb 19, 2014 12:06 pm
I reckon either would work well, just a small nitrile oil seal. They're a good company to deal with, very fast shipping on UK orders. Not sure about international, but expect they'll be fine. Any probs just give me a shout and I can order them up and forward them onto you.
Amazed you're having problems sourcing them your side of the pond mind.
Postby dhffr » Wed Feb 19, 2014 1:13 pm
Thanks. I'm amazed too. Most of the companies are manufacturers with huge minimum orders. I have looked for hours and came up with very little.
Will place and order and see how it goes.
D
dhffr
Postby Sub culture » Wed Feb 19, 2014 3:47 pm
That tends to be case over here if you want to shop with the main distributer.
For instance BSL brammer distribute the Freudenberg/Simrit range of seals here in the UK, the makers of the original 'simmerring' and other nice little exotics seals like 'Airzet' rings. They won't entertain orders of less than 25 seals, although the prices are good it puts you in the position of being a wholesaler.
Postby Tommydeen » Sat Mar 01, 2014 4:37 am
I have bought simmering seals from here http://www.rocketseals.com/ I did ask if they were made in imperial and I was told no only in metric. that was a couple years ago maybe things have changed.
Tommydeen
