no more Sombra Labs Receivers
Re: no more Sombra Labs Receivers
Postby Thor » Fri Aug 09, 2013 11:24 pm
You are a VERY smart man, Tim!
Postby Thor » Mon Aug 12, 2013 11:25 am
Correction: None of the currently manufactured on 2.4 GHZ can be converted to 75 Mhz. Only radios currently on 72 Mhz or other low frequency (27 Mhz, 50 Mhz, 40 Mhz) can be converted to 75 Mhz. The Futaba radios that have frequency modules can all be changed out to 75 Mhz, but the modules themselves cannot be modified. They must be exchanged for 75 Mhz modules. This is on the top shelf and very expensive 7-10 channel radios.
Postby JWLaRue » Mon Aug 12, 2013 12:57 pm
Okay...that's the answer I was expecting based on past experience.... :mrgreen:
Postby JWLaRue » Mon Aug 12, 2013 12:59 pm
Anyone interested in trading Multiplex Rf daughter cards for Sombra receivers?
Postby KevinMc » Mon Aug 12, 2013 4:50 pm
Likewise, I was also very surprised at the initial statement that current generation (2.4GHz) radios could be converted over to 75MHz, but I wasn't going to argue.
Don't be too put off by the idea of having to buy a "top shelf" 72MHz radio to have it converted to 75MHz. Because these radios were very expensive they tend to be well cared for, but now frequently sell for pennies on the dollar. The 9ZAP was Futaba's flagship for many years and used to retail for more than $2000 but can now be found regularly for as little as $200 second hand. You'll be hard pressed to find a more flexible radio than the ZAP, although it may take a while to get your head around the programming philosophy.
KMc Designs
SC #2870
SubComOn
KevinMc
Postby Thor » Mon Aug 12, 2013 5:21 pm
Kevin,
The only 2.4 Ghz radios that can be converted are the older style that ha ve the synth module. I don't believe those are made any longer, so you are correct.
Postby Thor » Tue Aug 13, 2013 3:00 pm
Sam,
Kevin is 100% correct on the top shelf 'used' Futaba radios. I just picked up a brand new in box Futaba 9CAP PCM on 72 Mhz for $185.00! I will send it off to Radio South to convert over to 75Mhz for $50. There are quite a few of these radios on ebay, new and like new, for $250 or less!
Postby sam reichart » Tue Aug 13, 2013 3:30 pm
I'll start watching eBay. Anything specific about that particular model that you picked up that one would need to be aware of?
sam reichart
Postby Thor » Tue Aug 13, 2013 3:41 pm
Sam,
I had one of these radios a few years ago and it was probably the nicest radio I have ever had. It is VERY easy to program, has a failsafe available for every channel. It is, also, a very easy radio to convert over to 75 Mhz. Kevin and Jeff like the Futaba 9ZAP, which is an excellent radio with more programming capability than the radio I purchased. They are readily available.
I have only seen one for sale, and it was the transmitter only. It seems as if the ZAP is a radio that does not come up for sale often, but it was a $2,000 radio when it was new!
Postby Bigdave » Tue Aug 13, 2013 4:46 pm
Matt.
If you can find a Hitec Spectra module on 75 you can just swap it out with the 72 plug in module in your radio.
But they have been discontinued and hard to find.
This will give you a synth radio.
DonO did this in his 9cap and 9 zap.
I have one in my Multiplex Profi too.
As does Jeff. BD.
Postby Bigdave » Tue Aug 13, 2013 4:54 pm
Postby Thor » Tue Aug 13, 2013 5:09 pm
Dave,
Found one on ebay and just bought it!
http://www.ebay.com/itm/300946250800?ss ... 1439.l2649
Thanks, BD!!!
Postby JWLaRue » Tue Aug 13, 2013 5:23 pm
....now we just need to have you get a Multiplex radio, then you'll be all set. :mrgreen:
You won't find a radio that is more flexible and easier to program.
Postby JWLaRue » Tue Aug 13, 2013 5:25 pm
Thor wrote:Kevin and Jeff like the Futaba 9ZAP, which is an excellent radio with more programming capability than the radio I purchased.
Which Jeff? (It's not me!)
-just curious,
Jeff
Postby Thor » Tue Aug 13, 2013 5:52 pm
Sorry, Jeff! I was meaning Multiplex with you. Forgot to get that in there....long day...
