Geared water pumps
Geared water pumps
Postby Marvin Harten » Tue Apr 23, 2013 10:29 pm
Does anyone have any information on submersible geared water pumps that can be used to pump water into and out of a ballast chamber?
Thanks.
Marvin Harten
Marvin Harten
Re: Geared water pumps
Postby Sub culture » Wed Apr 24, 2013 5:28 am
There are a few on the market. They vary in price, quality and size. What boat is it for?
Postby Marvin Harten » Thu Apr 25, 2013 1:18 am
This is for a basic Akula type hull that is approx. 80" long with an 8.5" beam. It will take 4lbs. - 6lbs. of water as ballast. The boat is really a test bed for electric motor torpedoes and some other electronic and mechanical ideas.
Thanks again.
Marvin Harten
Marvin Harten
Postby Sub culture » Thu Apr 25, 2013 4:57 am
Okay- big boat.
Geared pumps don't have a terribly high flow rate in relation to their size. A good pump is made by a company called Kavan. This pumps about 1.8 litres a minute, and can make about 40psi.
You would probably want two of these running in parallel for a boat your size.
Postby Johnredearth » Fri Jun 28, 2013 2:08 am
Hi
Try a simple valve instead of using a geared pump. [http://youtu.be/AQ8UrO42Mkg]
Johnredearth
