Push rod seals
Push rod seals
Postby Marvin Harten » Fri Nov 30, 2012 6:26 pm
Has anyone used the 1/8" dia. push rod seals from Sub-Driver.com? How are they attached to the face of the WTC? Were there any leakage problems? How do they compare to the older brass bushings with lip type seals in terms of length of use and replacement of seals? Any information would be appreciated.
Thanks.
Marvin Harten
Marvin Harten
Re: Push rod seals
Postby kazzer » Fri Nov 30, 2012 11:37 pm
Marvin Harten wrote:Has anyone used the 1/8" dia. push rod seals from Sub-Driver.com? How are they attached to the face of the WTC? Any information would be appreciated.
Thanks.
Marvin Harten
The seals are designed to be inserted into the motor bulkhead, which is drilled out to accept them. They are glued in with RTV, so are easily removable.
kazzer
