sub test
sub test
Postby kurt250 » Fri Aug 17, 2012 6:40 pm
just tested my alfa in my new test tank. before i put here in the water i ran the motor with no problems. the all of sudden the motor doesn't run eather out side the tank or in the tank. i have changes nothing in the propulsion end of the wtc. what could be wrong ? . batteries are charged both on the reciver and transmitter.kurt250
kurt250
Re: sub test
Postby salmon » Fri Aug 17, 2012 8:44 pm
I would do a check on all your wire connectors and check solder joints. Do you have a voltmeter? That would be a great tool to use to hunt down this issue!
tom
Re: sub test
Postby kurt250 » Sun Aug 19, 2012 12:12 pm
tom, i think i fried the speed controller. i have been reading and found that they suggest a fuse between the batteries and the drive section. will check with v.o.m. meter. will install a fuse. kurt250
kurt250
