Removing photoetch parts
Postby Wayne Frey » Wed Mar 28, 2012 9:15 pm
Is there a way to remove,perhaps chemically, photoetch parts from a fiberglass hull? If not, does anyone have 2 photoetch 1/96 hatches for a Scaleships Akula ?
SCM #653
SubCommittee Vice President 2006-2008
Author-Russian Submarines, Guardians of the Motherland
Member-Saint Petersburg Russia Submarine Club
Wayne Frey
Re: Removing photoetch parts
Postby Thor » Wed Mar 28, 2012 11:48 pm
Wayne,
What type of adhesive was used when they were first attached?
Thor
Postby Wayne Frey » Thu Mar 29, 2012 5:26 am
It looks like CA was used.
SCM #653
Wayne Frey
Postby StuartL » Thu Mar 29, 2012 8:32 am
It's been a while, doesn't CA degrade in hot water...?
StuartL
Postby Scott T » Thu Mar 29, 2012 11:10 am
One of these days when I get a round-tuit I'm gonna try this:
Take some paper and make a rubbing of the hatch and then temporarily
glue it to some soda pop plastic bottle or aluminum can and cut the pattern out.
Sorry no help unsticking the glued PE but maybe a way to reproduce it.
Scott T
Scott T
Postby salmon » Thu Mar 29, 2012 11:22 am
Your hobby shop should sell CA Debonder. It works, I know, I have used it many times.
http://www.supergluecorp.com/zap/zap-z-7-debonder
salmon
Postby JWLaRue » Thu Mar 29, 2012 11:30 am
If you are careful, you can try a mini-torch to heat the PE hatch. It will discolor the metal, but will destroy the CA bond. Just be careful of the fumes, thay are dangerous to breath.
JWLaRue
Postby StuartL » Thu Mar 29, 2012 11:53 am
JWLaRue wrote:If you are careful, you can try a mini-torch to heat the PE hatch. It will discolor the metal, but will destroy the CA bond. Just be careful of the fumes, thay are dangerous to breath.
... and lift fingerprints nicely :)
StuartL
Postby Sub culture » Thu Mar 29, 2012 2:01 pm
Acetone will break the CA bond, without damging the epoxy glass hull. The CA debonders I've seen are Acetone based, but I think they stick some other chemicals in there too.
Sub culture
Postby Thor » Thu Mar 29, 2012 8:23 pm
Wayne,
Go with the acetone or debonder (same thing at 10x the price). It will come up with patience.
Thor
Postby Wayne Frey » Thu Mar 29, 2012 9:07 pm
Thanks guys. I will try the acetone.
So, I need just one spare vladimer Akula hatch now, instead of two.
SCM #653
Wayne Frey
Postby Wayne Frey » Sun Apr 01, 2012 1:06 pm
I tried nail polish remover (acetone). I soaked the intended part once yesterday, and again this morning. I then took an exacto and it slipped right under the part and it lifted off clean.
For those who need to do that, this works.
SCM #653
Wayne Frey
