How much weight in a Revel Gato
Postby Jack B » Fri Feb 17, 2012 5:55 pm
So I was wondering if you guys could give me a ballpark Idea as to how much weight you needed to ad to the bottom
of your revel Gato? I know the size of the WTC & other factors make a difference, I'm just tryin to get a ballpark
Idea as to how much I'm gonna need. So let me know how much & where you placed your ballast.
And once again thanks for helping.
JAck B.
Jack B
Re: How much weight in a Revel Gato
Postby salmon » Wed Feb 29, 2012 10:06 pm
Jack,
I do not know. I am going to work on trimming my Revell Gato very soon. If no one responds, I will post what I find out.
Postby Sub culture » Thu Mar 01, 2012 7:39 am
Lot of factors influence that- displacement of pressure hull/wtc and the weight of equipment you have inside are the two main things.
Postby Jack B » Thu Mar 01, 2012 11:36 am
Thank Tom
Just wondering maybe you can help again, so what size WTC are you using?
The reason I ask is I am Building my own and am Trying to get an Idea as to how
large a tube is needed. I am using A 2 1/2 and have not figured the total legnth
Are you using a 2 1/2 inch WTC? are U using a Mfgd tube or did you make your own
I need to figure out how long I need to make the tube? Maybe some can Help
Thanks JAck B
Jack B
Postby salmon » Thu Mar 01, 2012 11:54 am
@ sub culture - you are right, but an estimate is helpful, do I need 30? pounds or 8 pounds? - I think that is all Jack and I are looking for.
@Jack - I am using D&E 2.5" WTC - the standard length is 30"
Postby Jack B » Thu Mar 01, 2012 12:23 pm
Thats it!!! Just in the ballpark, a starting point
Tanks Tom...
Jack B
Jack B
Postby Sub culture » Thu Mar 01, 2012 2:41 pm
Well a 30" long 2.5" diameter cylinder will displace about 5.3 pounds of water.
Lets say the module weighs a couple of pounds, radio and batteries another pound, and I reckon you will need to allow another pound or so to keep that Gato at it's scale waterline (note these are best guesses). That leaves you with about a 1.3 pounds of lead in the keel.
As my guesstimates are rough, I would say allow 1-2 pounds of lead, more if you add foam to improve stability.
Postby salmon » Thu Mar 01, 2012 2:56 pm
Thank you Sub Culture!
Postby Crazy Ivan » Thu Mar 01, 2012 8:25 pm
I don't know offhand what the breakdown is, but all totaled my Gato weighs in right around 9 pounds, ready to run. The sealed cylinders of the pressure hull total about 23 inches long by 2.5 inches diameter, supplemented with around 45 cu. inches of foam flotation, all of which resides just below the surfaced waterline. I'm not sure what the lead comes to and I would have to dismantle the boat to find out, but it has to be several pounds. Revel Gato's are tricky to get into stable trim on the surface. For all their size, the narrow tapering hull puts space for tweaking lead and foam at a premium. But then again I've read that the 1:1 boats were pretty squirrely in a beam sea and would roll heavily.
Crazy Ivan
Postby Sub culture » Fri Mar 02, 2012 6:38 am
Cylinder and foam adds up to a displacement of about 5.7 pounds- that's fairly close to Tom's cylinder. The hull will add weight, but that cancels out in the water as it's plastic and is the same density.
To get your nine pounds figure, that must mean the hull weighs in at three pounds- if that's the case, then no wonder they're tricky to get stable!
Postby salmon » Fri Mar 02, 2012 1:17 pm
Thank you! That is great information.
