Mold Making Problems / Questions
Re: Mold Making Problems / Questions
Postby raalst » Sat Jan 14, 2012 6:28 pm
the strong white flex material used/offered by Shapeways is basically nylon,
so it should be OK in water. It is also easy to paint
because it is slightly porous.
wall thickness might be a problem though...
Ronald van Aalst
Just here to Learn
raalst
Postby Sub culture » Mon Jan 16, 2012 1:53 pm
They do some other materials which can go down to 0.1mm (4 thou).
Sub culture
Postby Ramius-II » Mon Jan 16, 2012 2:55 pm
Thanks Guys!
The smallest dimension in use is 0.0300" or .762 mm and maybe a nylon master to make a mold from would be best as for some unknown reason the brass I am using causes the RTV to swell!
Just one more wire!
SC# 2268
WB6NSN
Ramius-II
Postby Sub culture » Mon Jan 16, 2012 4:51 pm
Something else you could try is Vinamold. This is a reusable meltable flexible plastic, so once you've finished with your tool, you can remelt it into a new one. It's similar to RTV, but the mould has to be capable of taking the heat, a metal tool will have no problems.
You can get it in different grades, the yellow stuff being the toughest.
Sub culture
Postby Bigdave » Mon Jan 16, 2012 5:09 pm
Hi Andy,
The problem with that is it is not available in the states.
I looked and the only outlet I could find you had to buy like $700 worth and open a account and guarantee to buy so much for the year. :roll:
Looks like cool product though. BD.
David Welch
Commodore SR-8
Douglas, 20K
Bigdave
Postby Sub culture » Tue Jan 17, 2012 6:43 am
Well it's a shame they don't sell it over there, but why is that a problem?
A block of this stuff won't cost a fortune to ship, and it should last the average modeller a long time. Perhaps the place that wants to sell you $700 worth might be prepared to send a sample for you to try out, either that or see if you organise a group purchase.
Sub culture
Postby Bigdave » Tue Jan 17, 2012 9:50 am
Hi Andy,
I had just learned about the product not to long ago and was still reserching the options.
If I remember right though most of the places that sold it over the pond did not ship to the US.
But as I said I did not do a lot of investigation.
Have you ever tried it?
It looked nice for making simple molds but I guess you have to be careful when melting it. BD.
David Welch
Commodore SR-8
Douglas, 20K
Bigdave
Postby Sub culture » Tue Jan 17, 2012 5:53 pm
I've used the Yellow vinamold ( hardest compound). Can't speak from experience about the softer compounds, guess they're better for subjects with large undercuts.
You do need to be careful about burning it, but you can heat it up in a domestic oven quite easily.
Here are a couple of suppliers-
http://www.tiranti.co.uk/subdivision_pr ... vision=502
http://www.glasplies.co.uk/fibreglass-s ... /vinamould
Sub culture
Previous
