Engel 212 glitching issue with tank controller
Postby fgroza » Tue Aug 09, 2011 9:27 pm
This problem became public when Dave Welch tried to run his 212. The "glitch" is in the tank controller board, as seen by a electrical engineer. When you try to extend the piston to pull water into the tank, it starts then stops almost instantly. If you physically move the gearing by hand so that the jackscrew is out about 1/2" it will work. However, if you retract it completly it goes back into the glitch mode. Tried moving micro switches, ground off the tip of the micro switch plunger with no great results. Dave went to the proportional setup and has had great results. Engel has not returned a answer to my inquiry about this but it may take some time.
Overall the sub runs great and looks killer in the water. I was just wandering if anyone else has this problem.
Frank Groza
photos by Jim Henson
fgroza
Re: Engel 212 glitching issue with tank controller
Postby Wheelerdealer » Wed Aug 10, 2011 2:57 pm
Disconnect the pressure sensor from the piston control tank board or wrap the leads around a ferrite ring and all will be well.
You could try rerouting the pressure sensor wires some other way but thats normally more effort.
Wheelerdealer
Postby Bigdave » Wed Aug 10, 2011 3:39 pm
Hi Ramesh,
Just curious how the pressure sensor would effect the board.
I still use it on my propo board and it has no issues.
That is one thing I never tried before I took out the stock board.
I am much happier with the propo board anyway. 8)
Color me confused!! :? BD.
BTW-Frank I found my leak in the 212.
The epoxy I used to install the motor bulkhead never hardened correctly and turned to soft stickey goo!! :twisted: :twisted: :evil: :evil: :evil:
I can't get it out with the ring installed so I have to scrape it out from the inside so I can add the correct epoxy.
AAAARRRGGGGGGG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :evil: :x :x
That is the last time I use this C##P!! :cry: :cry: :cry: BD.
Postby Wheelerdealer » Wed Aug 10, 2011 4:50 pm
Hi Dave, I have no idea why it would effect it :oops: Clearly its the position or lenght of the wiring affects the new controller board, as in the latest German instruction maunal they instruct you to fit a ferrite ring to the wiring to reduce noise...
"7.7 Um Störeinflüsse auf das DS-Anschlusskabel zu verringern,
die zum Druckschalter liegenden Kabelenden min. dreimal
durch den beilienden, blauen Ferritring führen (siehe Bild)."
Wheelerdealer
Postby Bigdave » Wed Aug 10, 2011 5:34 pm
Must have been a problem that kept showing up. Glad they tracked it down.
Thanks for the info.
Hopefully Frank will give it a try and see if it helps. :mrgreen:
The ball is in your court buddy!! :lol:
Go Frank Go!! :D BD.
Postby fgroza » Wed Aug 10, 2011 6:54 pm
Dave,
There was a ferrite ring of about 1/2" dia included in the kit. No explanation of what it was for though. I'm going to the shop to wrap some wire!!
I'll let you know if it works. I still like the dial a depth idea.
Frank
fgroza
Postby fgroza » Wed Aug 10, 2011 8:38 pm
Ramesh is the winner!! So far, no more glitches when retracted. Hope it works in the pond.
Frank
fgroza
