anyone tried this......?
Postby subkraft » Mon Oct 04, 2010 12:14 am
Before I pull a tx apart it seems a good idea to ask the question: Can I replace the 2 position switch typically used for retracts with a three position to control a pump one way, nothin on central and a solenoid valve the other?
The two position setup supplied moves the servo from one endpoint to the other when operated. Am I wrong to assume that a three position may give an additional neutral point? Be useful if it did......
Any advice appreciated
subkraft
Re: anyone tried this......?
Postby Sub culture » Mon Oct 04, 2010 4:00 am
Yep, should work without any problems. The radio should default to neutral position with the switch in the centre.
Postby Art Broder » Mon Oct 04, 2010 8:05 am
I did that successfully with my Ace Nautical Commander transmitter over 10 years ago.
Art Broder
SubCommittee#0060
Art Broder
