2.4 SPECTRUM QUESTION WITH SURFACE RUNNER
Postby dhffr » Wed Sep 15, 2010 8:28 pm
I am building a small surface runner and was wondering if the spectrum receiver will pick up the transmitter signal inside a WTC. The small antennas would be a maximum of 1 inch from the surface. Anyone tried this yet? Really want to use my DX6i because the receiver is so small and am running out of 75mhz stuff.
Darrin
dhffr
Re: 2.4 SPECTRUM QUESTION WITH SURFACE RUNNER
Postby Sub culture » Thu Sep 16, 2010 12:50 pm
Should be fine, but do a range check- the 2.4ghz bounces off stuff a bit easier than the lower frequency kit.
