brasswork?
brasswork?
Postby U-33 » Mon Jul 14, 2008 2:43 pm
Any of you guys expierenced in cutting and soldering brass can do me a small job? I can provide the drawings, all I need is a couple of brass brackets made up and soldered to another brass bracket with a brass bush installed, plus a pin made to connect the two.
Cash payment, of course...
Let me know?
Cheers,
Rich
U-33
Postby Sub culture » Mon Jul 14, 2008 2:56 pm
Can you post a drawing up here?
What's the application?
Postby U-33 » Mon Jul 14, 2008 3:15 pm
Pic attached Andy...hope it makes sense.
Rich
U-33
Postby Sub culture » Mon Jul 14, 2008 3:41 pm
So the triangular piece has a t-section on the rear face i.e. the bit with the 1/8" holes drilled in it (spacing of holes needed BTW).
Also, perhaps a stainless rod to swivel in the brass bushes as opposed to brass?
What is the application? If it's not heavily stressed the parts can be soft soldered. If they're stressed, silver soldered.
Postby U-33 » Mon Jul 14, 2008 3:42 pm
Sorry, forgot to tell you what it's for...it the stern gear on Sequel 5. The triangle bracket screws to the rear panel and supports the steering nozzle, the long brass strip is the bottom support and the pin is to connect the two and hold the nozzle in position.
Hope that helps?
Rich
U-33
Postby U-33 » Mon Jul 14, 2008 3:46 pm
Sub culture wrote:So the triangular piece has a t-section on the rear face i.e. the bit with the 1/8" holes drilled in it (spacing of holes needed BTW).
Correct Andy.
Stainless would be fine mate.
Answered this below...I hope!
U-33
Postby Sub culture » Mon Jul 14, 2008 3:46 pm
Gotcha. Soft soldering will do the trick.
Okay I'll see what I can conjure up.
Postby U-33 » Mon Jul 14, 2008 3:48 pm
Terrific stuff mate, thanks ever so much for that. Let me know how much I owe you mate, cash will be on the way. Oh...screw hole spacing...hadn't thought that through, I would think four or five screws would hold it secure?
Rich
U-33
Postby Sub culture » Tue Jul 15, 2008 8:56 am
Can you fill in the dimension with the question marks please.
Postby U-33 » Tue Jul 15, 2008 10:56 am
Sorry Andy, guess I failed there...miserably. 1/2" inch mate...half an inch.
Rich
PS..I've attached an image, sorry it's not too good, it's just a plastic mock up but it may give you an idea. The plastic triangle is the piece that needs replacing with the brass item. The bottom support isn't shown.
U-33
Postby Sub culture » Fri Jul 18, 2008 10:35 am
Okay. I've had a fish around in the brass drawer today. I don't have much in the way of 1/8" or 1/4" brass, I have lots of thinner sheet, which will be more than upto the task and will be less weight on the stern.
I'm loathe to go out and buy any brass, as the nearest brass stockist is some distance away.
Let me know if that's okay.
Postby U-33 » Fri Jul 18, 2008 10:42 am
Sounds fine to me Andy, if you think it's ok then I'll go with that. It has to support the nozzle top and bottom, that's the criteria...I leave the final decision entirely in your capable hands mate.
Cheers,
Rich
U-33
Return to SubCommittee GB
