Pod mounted motors..?
Postby U-33 » Sun Jul 13, 2008 3:45 am
I'm after a pair of pod mounted motors to go on the sides of Seaquel 5, something about the size of a Mabuchi 380. Must be complete with pods and more or less ready to install. I need them to be able to swivel about 45 degrees and preferably independently controlled.
Any ideas as to where I can obtain a couple?
Cheers,
Rich
U-33
Postby Rogue Sub » Sun Jul 13, 2008 3:29 pm
Please try to make this post only once. The three you made are excessive and unnecessary.
Thank you.
Postby Wheelerdealer » Sun Jul 13, 2008 5:44 pm
Norbert Bruggen sells motor pods http://www.modelluboot.de/
Wheelerdealer
Postby Sub culture » Mon Jul 14, 2008 3:05 pm
I think they'll be a bit too chunky for his submersible craft.
Why don't you make your own?
Fit two subtech seals in some old 35mm film canisters (speed 400 size I think), or run a brass bush with some silicone tubing on the end. Simple and cheap.
Postby U-33 » Tue Jul 15, 2008 2:13 pm
Problem solved now, thanks guys.. I've come up with a new, easy to build system which will give me two completely independantly controlled pods capable of revolving through 45 degrees, powered by two 380 sized motors.
Thanks for the input guys...
Rich
U-33
Return to SubCommittee GB
