Needed fairly soon..
Postby U-33 » Sat Jul 12, 2008 2:37 pm
I'm approaching the point with the building of Seaquel 5 where I need to spend some of the girlfriend's hard earned cash :o [hope she don't see this...] so I'm looking out for a decent five channel 27/40 mgs radio complete with mini servos [if possible] and a electronic speed controller. I'd rather line the pockets of one of you guys instead of helping a big commercial buisness get bigger, so if anyone has what I need for a fairly low financial outlay....
Cheers,
Rich
U-33
Postby Sub culture » Sat Jul 12, 2008 2:47 pm
The only complete set I've seen supplied with mini or micro servos is Spectrum gear, and you don't want that stuff in a sub.
I'd go for 40mhz if I were you, much less prone to interference.
I think you'll have better luck angling for a S/H set on the Mayhem forum TBH, as there are only about three or four U.K based modelmakers who frequent this forum.
Postby Sub culture » Sat Jul 12, 2008 2:52 pm
Postby U-33 » Sat Jul 12, 2008 2:56 pm
Thanks Andy...I've always used Futaba in the past, never let me down one, not even in the deep end of the Prince Regent Pool in Brighton with the Patrick Henry sat on the bottom.
I'll go trawling over at MBM then...ta.
Cheers,
Rich
U-33
Postby raalst » Sat Jul 12, 2008 4:45 pm
ebay or any local UK competitor to it ?
you want 40 mhx transmitter, 4 to 5 channels, matching receiver, crystals, esc and a few micro servos.
Postby U-33 » Sun Jul 13, 2008 1:45 am
I had a look around on ebay, nothing suitable at all really. I need the tx/rx, four servos, ESC and a mixer to operate the pod mounted motor individually and also to swivel them independantly as well.
More expense....
Cheers,
Rich
U-33
Postby Sub culture » Sun Jul 13, 2008 5:45 am
I would recommend a Hyperion/Berg receiver. These have microprocessors which clean up the signal, leading to zero glitching and buitl in programmable failsafe. You can get an 8 channel receiver, which is tiny, for about thirty quid.
http://www.aircraft-world.com/shopexd.asp?id=3278
Mini servos can be had for under a fiver now-
http://robotbirds.com/catalog/index.php?cPath=85_71_17
http://www.servoshop.co.uk/index.php?pi ... area=Servo
Transmitter-
http://www.howesmodels.co.uk/RadioContr ... rodID=1627
Postby U-33 » Sun Jul 13, 2008 5:52 am
That's exactly what I need Andy, many thanks for that....much appreciated.
Cheers,
Rich
U-33
Postby Sub culture » Sun Jul 13, 2008 2:06 pm
For control of twin thrusters, you may want to look at these boards-
http://www.dimensionengineering.com/Sab ... 2X10RC.htm
Two ESC's and a mixer built in for tank like control of the thrusters, all for about thirty quid- very compact too.
It comes with a built in BEC, but you will need a bit more oomph as the BEC can only supply a very modest current. Their range of switchmode BEC's are well worth a gander.
Postby U-33 » Sun Jul 13, 2008 2:19 pm
Sub culture wrote:For control of twin thrusters, you may want to look at these boards-
Man, where do you find this stuff? That will be perfect for what I need, should be able to turn Seaquel 5 in it's own length with contol like that. The idea is to use the thrusters not only to aid direction changes but to submerge and surface with them...I haven't room at the stern end to add dive vanes.
Thanks Andy..you are my hero!
Cheers,
Rich
U-33
Return to SubCommittee GB
