Help wanted - R-Class (1918)
Postby JBarche » Mon Jun 30, 2008 8:09 am
Hi all,
has someone some more information about this class. the few sketches and photos I found so far look quite interesting.
Jens
Yours
Jens
JBarche
Postby Davy » Mon Jun 30, 2008 10:00 am
Hi Jens,
What would you like to know?
They were a fascinating concept - fastest submarines underwater until the German Type XXI a quarter of a century later.
I built a 1:32 model of R4 in 2001 which was featured in the Association of Model Submariners Journal. I hope to have her sailing at the Norwich and Barrrow in Furness sub days this year.
David
Davy
Postby JBarche » Tue Jul 01, 2008 4:24 am
Hi David,
Currently I'm still in the plannig/early drawing stages. the basic hull shape should be quite ok, but I would need more details of the rudder arrangement (as far as I understand twin rudders), conning tower and bow area. Yesterday I saw the photos on subpirates which show no outer doors for the torpedo tubes but the dravings I have show these doors :?: .
If I start building (still some other things in the queue) I wold go for either R9 or 10 (Newcastle is near :wink: )
Jens
Yours
Jens
JBarche
Postby Sub culture » Thu Jul 03, 2008 7:08 am
I believe original works drawings are available from the National Maritime Museum, although this service is usually more expensive than sourcing plans from other avenues (i.e. John Lambert). Unfortunately, I think the NMM is the only place you'll be lucky.
Postby Davy » Fri Jul 04, 2008 9:20 am
Hi Jens,
Yes twin rudders with a skeg in between. (The narrow tapering stern made difficult access in my model. Eventually done by using a toothed belt to connect the rudders.)
Six torpedo tubes (She was very heavily armed) with doors.
John Lambert did not have drawings so I went to the Maritime Museum archive at Woolwich. Drawings cost me about £50 (then) for copying costs. I would love to be able to share them but copyright is a necessary evil!
Other useful sources are the RN submarine museum at Gosport. (Archive sources and very detailed photos for not too much money.) (BTW I will be at Gosport (with R4) on an AMS weekend at the RNSM 16/17th August)
Also look at a very interesting document BR3043 on this website:
http://submariners.co.uk
BR 3043 has some drawings in it also as well as interesting specs etc.
Also:
http://www.britsub.net
Hope this helps. What type of model/ scale are you thinking about building?
David
Davy
Postby JBarche » Mon Jul 07, 2008 5:28 am
Andy, David
thanks for the reply.
At that point the BR3043 together wit a drawing I copied from a book (can't recall the name but it still stis on a bookshelf at my parents' back in Germany) are my main sources for the drawings.
I'm not sure whether to build in 1/30 or 1/50. my drawings are in 1/30 at the moment but I can rescale them easily.
Im also not completely suer if I build a single hull boat like my ShinKai (still under construction :oops: ) or try the approach with a double hull and a sewage pipe as pressure hull. This would probably depend on the scale I build.
I can't make it to Gosport in August, but if you have some photos I would be thankful if you could send them
Yours
Jens
JBarche
Postby Sub culture » Mon Jul 07, 2008 5:54 am
1/50th (or perhaps 1/48th) would produce a nice handy sized model to tuck under your arm.
1/30th(1/32nd) results in quite a large boat, like David's. Looks impressive on the water, but a bit of a hulk to lug about.
I think wet hull principles would work well for both.
Current status
Postby JBarche » Mon Jul 07, 2008 1:33 pm
Hi,
here are some renderings of the model I use to make the drawings
still quite basic but you can imagine how the real thing looks like
Yours
Jens
JBarche
Postby Sub culture » Tue Jul 08, 2008 6:17 am
Photo courtesy of John Bass and Model Boat Mayhem.
Postby Davy » Wed Jul 09, 2008 4:37 am
Thanks for digging the photo out Andy.
That is 1:32 and she has a PVC sewer pipe WTC. The diameter of the PVC pipe basically determined the scale, I chose.
She is OK to lift etc. but I must say that my Holland in 1:32 fits under my arm better!
BTW memory is clearly failing me because I have been referring to my model as R4 whenshe is actually R7!
David
Davy
Re: Help wanted - R-Class (1918)
Postby JBarche » Sun Feb 21, 2010 12:02 pm
Hi,
I bring the topic up again because I have used the time and drawn a plan for these subs.
I needed the drawings anyway so I decided to make them looking a bit prettier in case someone is interested. My hobby budget is always in need of some top-up :wink: amd most of the work was done already.
So if anyone is interested, contact me.
Jens
Yours
Jens
JBarche
Postby Sub culture » Wed Feb 24, 2010 4:57 pm
David doesn't post on this board anymore- he left the Sub Committee last year.
His boat was based on a limited run of castings produced by UK modeller Nigel Edmonds.
The hull was based on the British built Hollands.
Here is a picture of Davids Holland taken at last years Norwich show in August.
and at Merstham Steam Show a couple of years ago.
Return to SubCommittee GB
