HELP NEEDED
HELP NEEDED
Postby AL » Thu Apr 17, 2008 3:24 am
HI DOES ANYONE LIVE IN THE LONDON AREA THAT WOULD BE PREPARED TO FIT AN AUTO LEVELLER TO A SHEERLINE TRAFALGER FOR A FEE THANKS AL
AL
Postby Sub culture » Thu Apr 17, 2008 10:34 am
What's the problem? Do you have a leveller to fit- they're very straightforward devices.
Postby Wheelerdealer » Thu Apr 17, 2008 10:59 am
Yes, its the simplest of thing to do yourself. What leveler do you have?
Wheelerdealer
Postby AL » Thu Apr 17, 2008 11:02 am
HI I HAVE AN SUBTECH AUTOLEVELLER I HAVE BEEN TOLD THEY ARE EASY TO FIT BUT I AM NOT VERY GOOD AT THAT SORT OF THING THANKS AL
AL
Postby Sub culture » Thu Apr 17, 2008 11:55 am
That's the easiest one of the lot to set up.
Have you installed it in the dive module/wtc yet?
Postby AL » Thu Apr 17, 2008 12:13 pm
HI I BOUGHT THE SUB AS A READY MADE KIT BUT THE AUTO LEVELLER HAD NOT BEEN FITTED THANKS AL
AL
Postby Sub culture » Thu Apr 17, 2008 12:53 pm
Right you plug the flylead into your rear hydrovane channel on the receiver. Connect the servo lead to the pins underneath the flylead on the APC-4. Observe polarity.
If memory serves me well, the medium jumper setting is best for your boat, but it'll be a case of suck and see.
Once you've done this, and have tested it working, fix the APC-4 to spare space on the equipment tray- observe you have it the correct way around.
Adjust the level pot with the aid of a small screwdriver and spirit level. Job done.
Postby AL » Thu Apr 17, 2008 12:58 pm
OKAY THANKS FOR THE INFORMATION I WILL GIVE IT A TRY AL
AL
Postby AL » Fri Apr 18, 2008 1:12 pm
HI SUBCULTURE HAD A GO AT FITTING THE AUTO LEVELLER TODAY BUT TO NO AVAIL DO YOU KNOW ANYONE IN LONDON THAT WOULD FIT THIS FOR ME THANKS AL
AL
Postby Wheelerdealer » Fri Apr 18, 2008 3:39 pm
Really, you can do this yourself. What happens when you hook up the APC as Andy describes?
If all else fails, turn up at the London Pool run and there will be plenty of help.
BTW your caps lock key appears to be stuck.
Wheelerdealer
Postby AL » Fri Apr 18, 2008 4:19 pm
hi thanks for that do you know when the first pool run is thanks al
AL
Postby Sub culture » Sat Apr 19, 2008 8:30 am
Dates are on this forum. But the first run is pencilled in for October.
Merstham is in May, not far if you're south of the river.
Check Show dates.
Postby Sub culture » Sat Apr 19, 2008 12:39 pm
BTW, have you got some pictures of your set-up- will help us understand what you are doing wrong.
Whereabouts in London are you? I'm guessing you're South of the river as you stated in another post you are only about 10 minutes from Brockwell lido.
Postby AL » Sat Apr 19, 2008 12:52 pm
hi im in crystal palace i dont have any pics its just a case of i dont feel confident enough of taking the sub apart thanks al
AL
Postby Sub culture » Sat Apr 19, 2008 1:55 pm
Rememebr the slogan on the Tamiya Frog 'No guts, no glory'?
Bit crass I suppose, but accurate.
You can't do much damage taking a sheerline module apart (famous last words), they're pretty straightforward things.
Have a go.
I'm in North London, so not quite round the corner.
Return to SubCommittee GB
