PARCHE update
New England US Local Chapter
PARCHE update
Postby expfcwintergreen » Fri Aug 22, 2008 4:43 pm
edit
Last edited by expfcwintergreen on Mon Mar 23, 2009 6:47 am, edited 1 time in total.
expfcwintergreen
Postby expfcwintergreen » Sun Aug 24, 2008 6:52 pm
edit
Last edited by expfcwintergreen on Mon Mar 23, 2009 6:48 am, edited 1 time in total.
expfcwintergreen
Parche bladder constraints
Postby Art Broder » Sun Aug 24, 2008 10:14 pm
Chris said,
"So... one of the problems I had was getting the boat to the surfaced waterline. The bladder was constrained by the upper hull, so I couldn't inflate it fully without bowing it.
Drastic surgery was needed."
Next time you or anyone else has that problem you might want to go up to the next larger size bladder. That will give you the same amount of air in the bladder with less height, and could solve your problem without major surgery. Sometimes you can get better scale waterline by just placing the bladder horizontally over the WTC, instead of vertically, using the overhang like saddle tanks.
I like any ideas that save work.
Art Broder
SubCommittee#0060
Art Broder
Postby Tony G. » Mon Aug 25, 2008 1:07 pm
Art
That is a great idea, I was having the same problem getting the 23 to water line, I think I will try that also.
Chris can't wait to see her running that is a great looking boat.
Thanks Doc.
Tony G. :D
Tony G.
Postby expfcwintergreen » Mon Aug 25, 2008 9:06 pm
edit
expfcwintergreen
Postby Tony G. » Tue Aug 26, 2008 8:42 am
Chris
Will a inner tube inflate enough to work? :?:
Tony G.
Postby expfcwintergreen » Tue Aug 26, 2008 10:25 am
edit
Last edited by expfcwintergreen on Mon Mar 23, 2009 6:49 am, edited 1 time in total.
expfcwintergreen
Postby expfcwintergreen » Mon Sep 01, 2008 2:53 pm
edit
expfcwintergreen
Postby petn7 » Mon Sep 01, 2008 3:10 pm
Excellent job! 8)
petn7
Postby expfcwintergreen » Mon Sep 01, 2008 3:21 pm
edit
expfcwintergreen
Postby petn7 » Mon Sep 01, 2008 3:42 pm
expfcwintergreen wrote:Thanks!
Getting to the finish line. Oh wait... There is no finish line with these things....
If there was, we wouldn't have as much fun!
petn7
Postby Rogue Sub » Mon Sep 01, 2008 6:27 pm
Looking really awsome man. How many boats dont need a stand!
Postby expfcwintergreen » Mon Sep 01, 2008 7:11 pm
edit
expfcwintergreen
Postby petn7 » Mon Sep 01, 2008 7:38 pm
Oh, those are built into the sub!
I didn't realize, but then again, I should have, as the Halibut showed the use of struts when sitting on the ocean floor.
8)
petn7
Postby Tony G. » Mon Sep 01, 2008 11:31 pm
Chris
She is looking great I can't wait to see her in the water Sat.
Tg
Tony G.
Return to SubRon4
